Polychronopolus's avatar
Polychronopolus
6 months ago
Download speed drops to ~30mbps on a 500mbps plan daily. Upload speed unaffected.
I noticed others have had this exact same issue in the past year.
Download speeds constantly drop to 30 mbps on a 500 mbps plan. | Cox Community
Some days the download speed will revert to what it should be. More often than not, nothing changes unless I reset the modem and router. Even then, the correct download speed only remains for a few minutes before reverting to ~30mbps.
I'm paying $150/month for this. The services advertised are not being provided. Not even close.
  • WiderMouthOpen's avatar
    WiderMouthOpen
    Esteemed Contributor II
    Download speed bottle-necking around 30-35Mbps is usually a sign the modem is entering "partial service" mode. This is caused by a problem with the signal going over the coax for service. Do you have Panoramic gateway? Also, how does the coax get from the street/pole to the room the modem is in? Any splitters, amp, filters? Last, when did the problem start and did anything change happen around then?
    PS. I assume this is affecting both wired and wireless connections.
    • Polychronopolus's avatar
      Polychronopolus
      No panoramic gateway. Modem is a Netgear CM1000 V2. Router is an ASUS RT-AX86U. Wired and wireless speeds are both affected equally.
      I live in an apartment, so I know the coax comes in via a box at the end of my building. Beyond that, no clue. Not certain of any splitters or the like between the outside coax box and my unit. There are no splitters or anything out of the norm between my modem and coax wall jack. I've swapped out various coax and Ethernet cables to rule them out as a potential variable.
      This has been an intermittent problem for months but only recently began to affect the network daily. In the past few weeks, I have received numerous notifications from Cox regarding repair work being done on the network infrastructure in my area. This problem has only escalated since then.
      I expect a technician needs to check the outside coax connection(s) based on similar forum threads I've seen regarding this specific type of slowdown.
        WiderMouthOpen
        Can you post your modem's signal levels from 192.168.100.1? See here. Also, do you know if anyone else in your apartment is having the same issue? Troubleshooting in a apartment is difficult because you can't always see all the coax wiring and it can be shared with different apartments in the building. There is also finger pointing with who is responsible for the wiring inside the building but not inside your apartment.
  • I'm having this exact same issue, starting yesterday. Here are the signal levels from my modem.
    Located in Phoenix, Arizona and I pay for 1gbps, started dropping to 32mbps yesterday randomly. I have a 4 year old Arris S33 modem so I don't mind trying a new one, but others have said new modems don't fix the problem.
    • LatitiaS's avatar
      LatitiaS
      Hello FireboltShade,
      We want you to get the speeds you pay for.  If you are still having issues, feel free to reach out to us via email at Cox.help@cox.com so that we may investigate further.
      WiderMouthOpen
      What speed do you get direct to the S33? Remember you have to reboot the modem each time you change the ethernet. Also, what do you see in your logs around the time of the problem? Don't post your logs unless you edit out your MAC address. Your signal levels look good though and I doubt it's a hardware issue.
  • I get my full speeds through the router, it seems when I'm saturating my network in full when downloading a game on steam is when it causes the drop (started happening yesterday)
    When it happens again I'll do a speedtest direct through the S33 and get the logs without the MAC address.
     I don't change the ethernet at all. Like I said everything's been working perfectly fine until yesterday.
      WiderMouthOpen
      Well it would make sense a speed test would show slow speed if you are saturating your network downloading a large file. Also, the download speed you get depends on the server you are testing from. I would normally suggest to do a Cox speedtest, but seems they shut down their servers and outsourced to Highspeedinternet.com which is a 3rd party internet reseller. I would trust speedtest.net or fast.com more.
      • FireboltShade's avatar
        FireboltShade
        Let me clarify. I download a steam game, I get my full gigabit speeds. then the speeds drop to 30mbps. Or I download something on my VPN. speeds drop to 30mbps. Then I stop downloading the steam game or get off the vpn and do a speedtest on my desktop, phone and laptop and they all get 30mbps.
        My router shows active traffic and it also shows a drop in total traffic to 30mbps when it happens. When speeds drop it comes back within 5-10 minutes but it's happening in a loop.
        It's happening right now and the modem status is the same as the pictures I sent earlier. The event logs say a lot of:
        -DHCP WARNING - Non-critical field invalid in response
        -TLV-11 - unrecognized OID
        -DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3
        -Started Unicast Maintenance Ranging - No Response received - T3 time-out
        -No Ranging Response received - T3 time-out
        -RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM
        -Dynamic Range Window violation
  • olivesage's avatar
    olivesage
    This is what is happening for us... Is anyone else experiencing this same issue and frustration??
    Our speeds are regularly less than 10mbps and they want to charge us for their tech to come out, but cannot articulate what their techs would be able to do for us. When we restart the modem, our speeds pick back up to about 300mbps, and then after about 20 minutes our internet slows back down to unusable speeds. I can tell this gets worse towards the end of the month as we use through data, but I pay the additional $20 for unlimited data, so what am I really paying for when I am stuck with dismal internet speeds? I am paying $170/month total for this and gigablast, and the only thing their support does is push their equipment for an additional monthly fee, along with another $10/month for their service calls. I understand the service fee to some degree, but since this is an issue with Cox throttling the internet, I would almost knowingly be wasting my money. I know not to expect 1 gig of internet speed, but for what I am receiving, shouldn't I be paying for the lowest internet plan, and not $170/month? Also, this seems to have gotten worse since 2Gig is now available.
    I have the recommended Docsis 3.1 modem, and am getting these slow speeds even when I am directly connected to the internet (not on wifi).
    olivesage
    Same thing happening here! I can't believe we are paying $150/month for this!
    • JulianN's avatar
      JulianN
      Hello, I am very sorry you’ve not had the best experience with Cox. I understand how important communication and reliable service is. We value your business, and we would be happy to help. Please email us your “full” name, “complete” address, and a copy of your post to Cox.Help@cox.com for further assistance. Thank you!
  • I signed up just to put my voice into this.
    I've been experiencing the same problem for about 2 weeks as well.
    I have a Netgear Nighthawk CM2000, and my downstream is only locking one of the 2 channels.
    Initially I was having dropped packets (Ping timeouts) about 5 or 6 consecutive pings dropped per hour, which were bad enough to know me off a Teams/Zoom meeting. A tech came over, and saw nothing on their pings. He did replace all the Coax terminations on all endpoints, and they even ran ping-plotter to my neighborhood, and didn't see anything. So they, of course, blamed it on my modem, being faulty, etc...
    Of course, on my end, I can't update firmware or do anything on it as firmware is pushed from their side. Magically, my ping drops stopped occurring. (That mostly proves that my modem was not at fault, but something on their side that got addressed)
    Fast-forward about one week, my download speed degraded down to about 28-30 Mbps (I am on a 2.5Gbps / 100Mbps) connection.
    I opened a ticket with support, and they started giving me a bunch of ridiculous suggestions to fix this, like "Update your OS", and "your Antivirus may be out of date". (I kid you not, I have the chat)
    I should mention, the tests I did were disconnected from my Orbi Mesh network, and connected directly to my laptop via an Ethernet cable, and receiving a public IP directly on my laptop. (So NATing)
    After a modem reboot, I can do about 2 or 3 speed tests at 2.2Gbps download speed, and then a few minutes later, it immediately drops back down to 28-30Mbps. (sometimes even down to the teens)
    I am willing to admit that my modem could be the culprit at this point, but it is literally the last "device" between me and Cox, and I am willing to buy another one and try it out, to rule out the modem being the problem, even though I am not convinced that it is, given that the issue with the ping request timeouts resolved itself without me touching the modem. But if I need to escalate the issue, I want to be able to say that I've literally replaced every piece of equipment on my end.
    I just really really don't want to have to replace the modem with their Panoramic Modem/Router/WiFi , because I have additional devices on my network that I need to be connected, and also want to be able to use my Orbi system.
    Does anyone have any recommendations on modems that work better than the CM2000? I would appreciate any insight anyone might have regarding this. I am at a loss, and I have no better alternatives for internet in my area. Hate being held hostage by a monopoly!
    p.s: I don't know about you, but the rep I was chatting with refused to give me a ticket reference number, but instead gave me a phone number to call, to start the process all over again. He also refused to have a manager call me after I requested it. They also don't allow you to save your chat transcript after a chat. This should tell you something about accountability and obfuscation of their communications to disarm the customer from building a case. What a joke of a company.
  • Hi,
    I apologize that you have had this experience. This does sound like a localized issue.  Have you tried connecting the modem to a different power outlet and plugging it directly into the outlet if you are using a power strip? Sometimes, a fluctuation in power can cause intermittent connection issues or slow speeds.
    We will be glad to investigate this further with you, Please contact us privately with your account information. Our email address is cox.help@cox.com. Please be sure to include your name, full street address, and a link to your forum post. As for which device to go with I'm not able to recommend any specific 3rd party modem, but we do have a list of all modems that are verified compatible with our network listed at https://www.cox.com/residential/support/cox-certified-cable-modems.html
    Greg
    • gkhairallah's avatar
      gkhairallah
      Thanks Greg,
      The modem is plugged into a UPS (APC Pro 1500S) which is an even better and more reliable solution than a regular power strip . So I can confirm that the issue is not a power fluctuation problem.
      Regarding the cable modems, yes, I am aware of the "certified" cable modems, where support immediately refuses any sort of advanced troubleshooting beyond making sure it gets a basic signal. Their first recommendation has been to rent me the Panoramic device (the only supported one, apparently)
      The CM2000 I am using is in fact on that list, by the way: https://www.cox.com/residential/support/netgear-cm2000.html
      For the record, I have noticed that the Downstream Channel on that modem has been blinking, which means it's not on full service, and the Cox tech that came to my house even showed me that his testing equipment is also showing Unhealthy status
      I will send an email to cox.help@cox.com and reference this thread.
      Thank you for the response.
      • HeatherS's avatar
        HeatherS
        You are welcome for the reply from Greg. He's away from his desk at the moment so I am stepping in. We look forward to your email and further assisting you.
