- RexxNew Contributor III
I am also having the same issue -- I was about to start a new topic about it, but I found this thread.
To me it seems that a current update was done to the YouTube App on the Contour 2 console -- and that now affects this function. Someone with a higher pay grade needs to report it to someone in charge of the YouTube APP feature for the Contour 2 and it's remote control.
Before, after conducting a Search in YouTube and selecting a video to watch, and then if you wanted to to back to the recent search to select another similar video, all we needed to do is press the LAST button on the Remote, but that no longer has that function.
Plus I noticed that at the bottom right side of the screen it shows me an icon for Back on the screen, but there is no way to highlight/select that for some reason.
The LAST button works well, when you are simply navigating the YouTube app -- it will take you back to the menu, but once you are watching a video, there is no way to go back. You only get EXIT, but that closes the YouTube app -- and then you have the burden to conduct your search again, and again, and again.
lisah your suggestion to use the Left Arrow doesn't do a thing for me. It will only rewind the video to the start, but doesn't return me to my previous search or etc.
bearone2 the batteries are good. No issues there.
So I suggest both of you to attempt to do a search, then select a video, and then try to get back to the YouTube menu to select another video of your search and etc.
The only workaround I found was to make a voice command to return to the YouTube menu, by simply saying "YOUTUBE MENU", but the problem is that I want to select something else from my recent search or from videos I tag to watch later, so I want to continue watching from where I left off during that page and etc.
- AllanModerator@Rexx. Thanks for the suggestion and we will forward your request to our programming/video team on your behalf. -Allan, Cox Support Forums Moderator.
- BrianMModeratorI just tested this myself and the last button seems to be working. I was able to complete a search, watch part of the video and then click last. It took me back to the original search that I just completed. Has anyone tried resetting the Youtube app yet to see if this will restore this function? This can be done by clicking on settings at the bottom left and then scroll down to reset app.
Brian
- LisaHModeratorHi Worldsfair. The best way to get to where you want to go while on YouTube is to use the left arrow button the remote. - Lisa, Cox Support Forums Moderator
- bearone2Contributor III
batteries?
- 7 months ago
- 12 years ago
- 12 years ago
