mzjordan
6 years agoNew Contributor II
I've experienced the same issue allan since my last Contour update. It's most irritating since I prefer to watch youtube from my Contour box. The Last button no longer works to navigate.
BrianM
6 years agoModerator
I just tested this myself and the last button seems to be working. I was able to complete a search, watch part of the video and then click last. It took me back to the original search that I just completed. Has anyone tried resetting the Youtube app yet to see if this will restore this function? This can be done by clicking on settings at the bottom left and then scroll down to reset app.
Brian
Brian
- RH-V6 years agoNew Contributor
This works.. I just tried it.. Thanks..
- Woody_P6 years agoNew Contributor
Brian. I can handle losing history but does that mean I will also lose all saved you tube videos?
- LisaH6 years agoModeratorHi Woody P. You would need to verify those tube videos are saved under your profile online before trying this. As updates happen quite often, this may not work, however, it never hurts to try. - Lisa, Cox Support Forums Moderator
- mzjordan6 years agoNew Contributor II
That worked! Thanks!
