Sort By
- JonathanJFormer Moderator@coxprblms
The remote commands are run through servers on our end and not necessarily the box itself like previous platforms. So if the box is experiencing connection/signal issues, you would not be able to do any of your normal commands at that time.
Cox Moderator- coxprblmsNew Contributor III
So when I press play on a recorded show the remote control sends the signal to the DVR which then sends it through the coax connection, out my home, over miles of connections to servers in a data center somewhere in the world, then the servers interpret the "play recording" message and send the signal back to the DVR telling it to play the recording?
- CurtBValued Contributor III
A cable signal is required to playback recordings on your local DVR. It works the same as when you posted about this over a year ago.
- 3 years agoFlighthawk
- 4 years agoJC
- 6 years agoBen12
- 10 years agoneeksor
