- WiderMouthOpenEsteemed Contributor II
So I can look over the manual, what model TV do you have? Also, how do you have the cable box connected to the TV? Any audio system or sound bar?
I also have a Samsung TV and the audio stops sometimes and I have to power cycle the TV to get it to work. Have you tried that?
You can find the model number by going into Settings > Support > About this TV > Model code. I have the UN43NU6900.
The audio just stops? Is the audio from your TV speakers? I know you've ensured all firmware is up-to-date. Where does your TV gets its programming?
- DRVEGASValued Contributor
He said 1 second
The speed of your audio signal may actually be correct or normal, but your video signal may be out-of-sync.
Disable any video-processing on your TV (and/or receiver), such as motion enhancement, video enhancement, video noise reduction, etc
If your audio and video get back in sync, you can re-enable enhancements one-by-one to find the culprit.
My Samsung has the same issue but I'm using Dish Network not Cox 🤔
Lots of kudos in here...but we ain't fix nothing.
- 4 years ago
- 12 months ago
- 6 years ago
- 2 years ago
- 8 years ago
