So I can look over the manual, what model TV do you have? Also, how do you have the cable box connected to the TV? Any audio system or sound bar?
I also have a Samsung TV and the audio stops sometimes and I have to power cycle the TV to get it to work. Have you tried that?
You can find the model number by going into Settings > Support > About this TV > Model code. I have the UN43NU6900.
The audio just stops? Is the audio from your TV speakers? I know you've ensured all firmware is up-to-date. Where does your TV gets its programming?
- DRVEGAS2 years agoValued Contributor
He said 1 second
::edit:: Wait, who were you talking to, me or OP?
Yes, it happens if the TV has been in stand by for a long time. Mostly happens when using the built in apps like Disney+ but I think I have had the issue using blue-ray too. Hook up is simple, just the TV and a Sony BR player via HDMI.
Sometimes I can fix it by rebooting my TV
