Becky
Hi David64, we haven't had any reports of problems with the USA Network. Please disconnect the coax cable from the cable receiver and then reconnect it, making sure it is finger-tight. Unplug the power from the cable receiver for 2 minutes, and then plug it back in. After the receiver completes the reboot process, see if the issue on the USA Network continues. -Becky, Cox Support Forums Moderator
MAB
6 years agoNew Contributor II
I have noticed this also with the sound on channel 23 DISCH-there was another channel will have to check it later
- 7 months agojillrenee1973
- 2 years agoAndyH
- 5 years agokristiemom26
- 3 years agokylejjf
