nrgon If you're utilizing upload speeds in the Las Vegas area and are having persistent problems continue to post evidence here please. When you experience problems next time run an MTR test -> https://portableapps.com/apps/utilities/winmtr_portable - and post the results here.
Make sure on OBS you remove the global fastest twitch server in settings and replace it with the most local twitch server you can find; start streaming and look for the server ip info on your twitch page, plug into the MTR then run this test for about 10-15 seconds and post the results here.
Also make yourself a spreadsheet and log different speedtests periodically throughout the day from different sources. Dslreports/speedtest.net/fast.com. I'd also recommend getting a google meshing router because the APP controls are pretty great and the internal network speed test shows whats actually coming and going through your router. When I showed the onsite techs these logs and live tests from the router's APP they could see clearly this is an external issue and it #1 gets them off your back about your equipment, #2 you have evidence and #3 they shouldn't be charging you for those visits.
Also in Las Vegas. Arris has many pages of recorded data. Read my post.
