- CrystalSFormer ModeratorHello @Pete123456,
I can certainly assist you in how to manage audio description and TV voice guidance. Please the links below.
www.cox.com/.../using-contour-tv-voice-guidance.html -Contour TV Voice Guidance
www.cox.com/.../learn-about-audio-description-service.html -Audio Description
Crystal S.
Cox Support Forum Moderator - BruceHonored Contributor III
I remember this discrepancy from 2 months ago and it appears bob.p found a solution on the bottom of the post.
forums.cox.com/.../history-channel-has-an-annoying-narrator-that-i-can-t-seem-to-turn-off
- Pete123456New Contributor
Thank you for your suggestions. Sadly they did not work. We called technical support and he reset the box and the problem remained (we had reset the box perviously to no avail). The tech who was quite nice was not sure what was causing the problem. its been going on for 2 weeks now. Any additional suggestions appreciated. Thanks!
- markn2New Contributor
Having the same issue and as always tech supports answer is "replace the box". I was able to figure out that for Fox if you turn on Audio Description it actually turns off AD. The only issue is when you watch shows that have SAP enabled you will hear them in Spanish so you have to turn off AD. The strange thing is that it's only been happening for the past 2 weeks. Good Luck!
- ceeflintNew Contributor
We have been having the same issue with audio description suddenly starting on a number of different channels. We tried every setting we could think of to turn it off but stumbled upon turning the SAP setting to Spanish. For some reason it stopped the audio description but didn’t change the language and we still heard it in English! Tonight on Fox we heard no commentating on the football game, so I changed the SAP Setting to Spanish and the English commentators started! It’s all messed up!
- JonathanJFormer Moderator@Pete123456
Are you having this issue on all cable boxes if more than one? Also, what fox channels are you experiencing this on?
Cox Moderator
- 10 years ago
- 11 months ago
