Audi74's avatar
Audi74
2 years ago
No Audio on MSNBC for Days
I have called Cox and reset box multiple times.  Sometimes, after the lengthy reset, the sound works but only for a few minutes.  The last call someone told me that it was a nationwide problem with both MSNBC and Fox News.  I hate Fox News and there has never been an audio problem.
Anyone else having this problem?
  • I just reset all 3 of my cable boxes and finally have sound from CNN.
  • charles16's avatar
    charles16
    2/5/24, having this same problem (no audio on MSNBC).  This has been happening off and on for quite a while.  First time I spoke with tech, they rebooted my cable box from the help line - MSNBC audio started again, but after a couple days, it was gone.  Next time, tried resetting from home (pulled power cable for 30 seconds), did not fix.  Took the cable box in and swapped it for a new one, same thing is happening again today.  Checked the SAP setting, appears to be turned to English.  Have checked other channels, they seem to be fine, for us it's just MSNBC.  Resetting cable boxes is NOT the solution, at least from home.  If somebody told me some right wing nutjob who works at Cox is doing this to MSNBC, I would believe them...
    • ChrisJ2's avatar
      ChrisJ2
      Hi, Charles. I'm so sorry for the audio issue you're experiencing and I want to help. Please email us the physical address and any other pertinent information to Cox.Help@cox.com with your name and a copy of this forum message. I would be glad to look into this for you.
    • Ichabod's avatar
      Ichabod
      Hi Charles.  Did this get fixed? I'm having a very si alarm problem about which I just posted. Thanks.  Joe
        charles16
        No, happened again yesterday.  Rebooted cable box and fiddled with SAP and it's working now, but recordings made while audio was out have no sound.
  • JTaxman's avatar
    JTaxman
    Same problem on CNN channel on cox contour box.  Started Wednesday.  Service via chat just had me restart modem.  Not effective.  Planning to call (rather than chat) to see if they are having a systemwide problem.
      • Becky's avatar
        Becky
        Hi Everyone, resetting SAP is certainly a good place to start if one channel has no audio and your other channels are fine. If you continue to experience audio issues, please email my team at Cox.Help@cox.com so we can further investigate.
    • CurtB's avatar
      CurtB
      Honored Contributor
      SAP was my first thought too.  I don't watch MSNBC or Fox News, but programs on those channels during random checks over the past couple of days didn't have an SAP channel.
  • Skbeene1's avatar
    Skbeene1
    I am experiencing the same issue with CNN channel 8  that is the only station with no audio
    • Skbeene1's avatar
      Skbeene1
  • earnon1's avatar
    earnon1
    This began happening for us just yesterday, 1/16. Called Cox and reset through the phone menu. Audio returned to normal.
    Tonight, 1/17, it happened again. We’re now on the second reset through the phone menu. After the first, the audio worked for 15 minutes then disappeared again. The adjacent channels have no issues.
    Will be calling to speak to a live person tomorrow I guess when I muster the patience. 🙄
  • CurtB's avatar
    CurtB
    Honored Contributor
    Audio and/or video issues for specific channels can be caused by a weak mainline signal or faulty equipment that affects those channel frequencies.  If you have Cox Complete Care, schedule a tech visit to check your signal.  If your dropline connects to the mainline at a pole, be sure to request a tech with a long ladder.  Ask the tech to check your signal at the tap.  If possible, schedule the visit during a time when the issue occurs most often.  If you don't have CCC, Cox may charge for a service call if no issue is found with their signal or equipment.
