Greetings,
Back on my Cox October 2020 bill, they announced the following:
IMPORTANT INFORMATION ABOUT YOUR COX
PROGRAMMING HD CHANNELS on 1000's
Effective on or after 12/3/2020, we're making it
easier to watch the channels you love. We are
removing the duplicate HD channels on 1000-1950. You can still enjoy the
programming previously on these channels by tuning into the
lower 2 or 3-digit corresponding channel number.
Example: 1010 go to 10 / 1143 go to 143
Your DVR recordings, favorites and parental controls won't be
affected, so you won't have to do a thing.
To this day, this change has not occurred on my end, though I've reset my Cox cable box numerous times since December 2020 to see if it'll update (using both the online reset tool and by unplugging the power & cable lines from the cable box).
In my channel guide, I still have the 2-digit HD channels and the corresponding/duplicate 1000-series HD channels. For example, I have a channel 24 and 1024. If I favorite either channel, both get favorited. I can watch either channel, as I cycle through my favorite channels.
I understood why this duality of channels existed during the years that Cox was transitioning from SD to HD. But according to the Cox announcement on my bill, this condition would be eliminated and shouldn't exist any longer.
So what's going on here and is there a way to resolve it?
Thank you
Will changing the Guide View to HD Channels only remove the 1000+ channels?
Thank you, Becky.
If using a CableCARD in a TiVo, will the 1000's channels still be broadcasting a signal? Since both channels are Mapped to the same frequency.
I need to know if I need to change the channel number for all my Season Passes.
