susuknitter's avatar
susuknitter
Local channels keep cutting out. I can sometimes fix it by disconnecting and reconnecting the box and tv. Is there a permanent fix?
I have sent multiple reset requests and nothing happens
  • I have this problem in topeka with the local NBC channel. So broken up we usually end up turning it off.
  • KevinM2's avatar
    KevinM2
    Are all receivers impacted or only one receiver? Does an error code appear on the screen? Generally, rebooting devices only add temporary relief for signal-related issues. Do you have a splitter in the home? -Kevin M. Cox Support Forum Moderator
    • susuknitter's avatar
      susuknitter
      I do have a splitter.  One end to the cable box and the other to the internet/phone modem
      • Allan's avatar
        Allan
        @Susuknitter, Is it possible to temporarily bypass the splitter to see if that helps? -Allan, Cox Support Forums Moderator.
