susuknitter
6 years agoNew Contributor
I do have a splitter. One end to the cable box and the other to the internet/phone modem
Allan
6 years agoModerator
@Susuknitter, Is it possible to temporarily bypass the splitter to see if that helps? -Allan, Cox Support Forums Moderator.
- susuknitter6 years agoNew Contributor
It does help. But then I don’t have internet access
- KevinM26 years agoFormer ModeratorTo confirm, when the splitter was removed, you are no longer experiencing local channels cutting in and out? By removing the splitter, this temporarily disables the internet service, however, this helps us to determine if the issue may be related to the splitter. If the issues involving your Cable TV have been resolved, then I suggest replacing that splitter, as it may be faulty. Splitters can slowly degrade over time or simply fail without warning. -Kevin
It’s possible. I will try a new splitter to see if that helps
