BatmanFanatik's avatar
BatmanFanatik
a question about contour or contour 2 cable boxes (NOT THE DVR)
I was wondering .... can I have 2 contour boxes (not the DVR kind),  in the same house (thus replacing a mini-box)? example... 1 in living room and another in bedroom...
Or better yet,  if I found an extra contour box or contour 2 box (say at goodwill, ebay, amazon, etc...), would I be able to use it in another room instead of the mini-box as I have noticed that the contour box in our living room has nicer features such as more programming and voice remote than the basic remote and programming associated with the mini-box in my room.
Any answers on this subject would be great... especially if I find out that I can simply replace the mini-box with say a "goodwill, ebay, amazon, etc.." contour and only pay $2.99 instead of whatever cox is charging to rent their contour receivers each month. Would there be any problems just plugging it in where the mini-box was??
  • Hi BatmanFanatik. You can have additional contour 2 boxes in your home, however, you would need to rent them from Cox in order for you to be able to enjoy all the features that you love. Thanks, Lisa - Cox Support Forums Moderator
      If a customers does not return a cable-box to Cox, does Cox block its MAC address on the network?
      • Andrew_Wees's avatar
        Andrew_Wees
        Contributor III
        doesn't matter they don't all customer owned cable boxes
