Here is a screenshot of my normal speeds now in Las Vegas. 700+ in the morning and 10 in the evening. Everyday for the past week. This is definitely a problem [at minimum] with the CMTS.
These speed tests are taken hardwired out of the modem (CM100). If I use a completely different modem (Arris SB8200), same result. My neighbor gets the same speeds too (also SB8200). I have new RG6 pulled (by Cox (twice)) to my DMarc where it hits a bonded bullet connector to another brand new piece of RG6 straight to my modem. No wall jacks/attenuators/splitters/taps, nothing. There is nothing left to troubleshoot from the curb to my house. It's all new...and apparently acceptable or I'd never hit 700+
I get what you're saying though and that's all possible scenarios in a lot of cases, but not in my case.
The simple fact is Cox's greed has over subscribed and their nodes can't handle the demand.
I’m running into the same exact problem here in Henderson. Totally fine speeds in the morning and by afternoon we are down to single digits. I thought it was possibly a modem problem. I didn’t have any issues until I upgraded speeds and got their modem (pano). I just ordered a new modem in hopes that would solve the problem but from what you are saying it looks like I’ll run into the same issue. I had 3 techs out here over the past two days and they can see that the node is overrun but why the sudden issue of the single digit speeds? People have been working from home for months. What changed this past week?
- FatDaddyWampus5 years agoContributor
I'm at Eastern/215. It's definitely not your equipment. If it was why would you ever get anything above single digits right? My node was split a couple of months ago to relieve congestion, but apparently something else has happened since then in the past week.
- zzzz5 years agoNew Contributor
Same here- Pebble/Pollock
- Calebjyinga12 months agoNew Contributor
The length of your subscription. I've noticed after getting rid of cox and getting it back that I get THE BEST WIFI EVER for about the first couple weeks, sometimes the first month. Then I get 1/10 what I am paying for afterwards. This seems to be the same no matter what plan I choose and fiber isn't available in my area. I literally just cancel and take the motum back every 2-3 weeks and get 700+ download and over 100 upload, latency is usually 20-25 ms. By the second month the latency goes up to 150-200 ms, download speed gets AT BEST 150 mb and upload is at best 10mb. Somehow when I start a new plan every month after canceling for a few hours and starting a new account my internet magically becomes better. Idk if the motums are made to work for 2-3 weeks but my wiring hasn't changed and I use an ethernet cable for my only device I use heavily during the day.
