You wouldn't make that bet because there are no network settings, selections or options in the cable-box version of Contour.
yes there are network settings but not what's required to do what what the op needs.
i posted about needing to switch to wifi to get a needed samsung tv update several months ago.
OP wouldn't have used the Contour remote to configure WiFi for a TV because the cable-box version of Contour doesn't have network settings. From what you've written, you have the Wireless 4K Contour Steam Player. This is an entirely different platform...hence it's name.
- bearone25 years agoContributor III
whatever i have, i just shared what i had to do to receive the samsung tv updates.
op hasn't been back, maybe my suggestion worked.
perhaps he should've tried using the toaster update!
Your suggestion was more of an assumption than a solution. For example, if I said, "My car won't start." You say, "Try using its key." Your "solution" only begs the question: What do you think I was using to start my car?
- 10 years ago
- 9 years ago
- 9 years ago
- 2 months ago
