netnewbie's avatar
netnewbie
Problem connecting to Outgoing mail
Hello
I am having an issue connecting to the Outgoing mail server using Outlook. I have setup the Outlook for IMAP, and with the settings I can connect to the Outgoing mail server using a Verizon hot spot, and send email. But when I take the same laptop, with the same IMAP configuration,  and plug it by cable into my Cox internet router, I cannot connect to the Outgoing mail server, nor can I telnet to the server. What do I need to do to connect to the mail server?
  • No problem. If you do not intend to update the thread anymore, can you mark it as solved? Makes it easier to know who still needs help.
  • Tecknowhelp's avatar
    Tecknowhelp
    Valued Contributor II
    What are you using for your IMAP and SMTP settings? What error do you get when you telnet? I think something is going on with Cox's email and your technical data could be very useful.
  • netnewbie's avatar
    netnewbie
    When I try to telnet, I get the message that the connection to the server cannot be opened. When I try the IMAP settings I get the message "Send test e-mail message: Outlook cannot connect to your outgoing (SMTP) e-mail server." I have mail1.alexandrialighting.com as the inbound and outbound server, and I have the authentication set both on the configuration page and in the More Settings Outbound Server tab.
    Tecknowhelp
    What are you telnet-ing  to? Cox's IMAP? Cox's SMTP? What port? Can you copy/paste the results?
    Then how is this a Cox email problem? You aren't using Cox's email servers. Are you forwarding your email from the domain at the DNS level? I notice some things like not having a good PTR on the MX and not allowing open relay but not sure if those are relevant to your configuration. I do notice they block Telnet though, so that explains why that wouldn't work.
    The thing I notice that probably is relevant is mail1.alexandrialighting.com doesn't use SSL or TLS for SMTP. That means you are trying to send SMTP via port 25, which is blocked on Cox to all SMTP servers except Cox. See here to confirm. I would suggest contacting your web admin (or who ever you pay for email) and ask them to enable TLS or suggest something to use when you CAN'T use port 25.
    What settings are you using? You need to use either port 465 with SSL or port 587 with TLS, neither which seem to be open on that server.
    netnewbie
    I'll see if port 25 is closed on my Cox router. I would try to telnet to the mail server, and would not be able to. It's not a Cox email problem, it is that I cannot connect to an email server using Cox internet. I can connect to the server using Verizon WiFi. I am trying to find out what could be causing the difference.
  • ChrisL's avatar
    ChrisL
    @newnewbie
    Port 25 is closed at the modem and not the router, you will not be able to see this from your end. As such, only connections to smtp.cox.net are permitted on port 25.
    Tecknowhelp
    It doesn't matter if port 25 is closed on your router. It IS closed/blocked inside Cox. Cox blocks all the ports seen below:
    PortTransportProtocolDirectionReason for Filtering
    25 TCP SMTP Both
    Note: SMTP is only permitted outbound to Cox-provided SMTP servers.
    SMTP Relays
    80 TCP HTTP Inbound Web servers, worms
    135 UDP NetBios Both Net Send Spam / Pop-ups, Worms
    136-139 UDP, TCP NetBios Both Worms, Network Neighborhood
    445 TCP MS-DS/ NetBios Both Worms, Network Neighborhood
    1433 TCP MS-SQL Inbound Worms, Trojans
    1434 UDP MS-SQL Inbound Worms, SQLslammer
    1900 UDP MS-DS / NetBios Both Worms, Network Neighborhood
    That is because the server blocks telnet access.
    That is ironic because Verizon also started blocking port 25 recently too. Sometime in October I think, so probably right after you switched. I know because I have Verizon FIOS. See Verizon article here and forum post here. Take note of the forum post, because it offers different solutions people used to get around the problem, however it is not for the layman. Who do you pay for email? Godaddy?
    Tecknowhelp
    netnewbie said:
    We have our own mail server.
    Do you mean on site at the Cox internet service location? If not, where or by who? No offense, but it doesn't sound like you set up the server. Would it be possible to get the person who did involved?
    netnewbie
    It's not on site at the Cox location. It is at another facility, and I was testing being able to access it from my home. Since I could access it through my Verizon hot spot, but not my Cox modem, I was wondering what could be causing the issue.
    Tecknowhelp
    Are you not giving specifics for privacy reasons? If so, my apologies for digging. If not, who manages your email? If I know, then maybe I can search how other users of that email are handling the problem.
    When was the last time you tried? I think Verizon started blocking the port last month.
    Because Cox blocks the port you are trying to use. AFAIK so does Verizon now, but maybe their Wifi Hotspots are different then normal Verizon FIOS. Either way if you want to be able to send email to that server you need to find a way to use a different port. If you are looking for a work around until then, try using http://mail1.alexandrialighting.com/_index webpage and send email through there.
