Alert new customers, when you sign up for service you are getting a refurbished box that breaks constantly and fees will be charged for coming out to replace a refurbished box with another refurbished box. Im going on my fourth box in 4 months. Apparently the refurbishers aren't able to fix the boxes to last more than a month. It's getting worse. And unless you live in an area with fiber optic lines this will continue. I was personally told this by the last 2 techs that came out.
That is if the tech qualifies the "fix" as a Cox problem. If a tech simply replaces a box, sure, it's was faulty rented equipment. However, if a tech does multiple actions and the problem eventually resolves itself, what exactly fixed it? I'm sure the techs are told to not blame Cox for the fault. Cha-ching!
