DRVEGAS
3 years agoValued Contributor
Question
How do I delete an older post here? All I can see is the option to edit an older post🤔
I don't think you can. Why would you want to?
Only because it's no longer needed but I guess your right that we can't delete them.
It's a good idea to keep questions because someone else may search google and come across them. It helps answer questions before they are even asked. They are locked after 1 month of inactivity though.
As long as nobody replies directly to your previous post, you can delete it. If someone does reply, it's locked in; however, you can edit the replied-to post.
Oops...you may be referring to an original post within the Forum. No, can't delete it. However, I've never tried to delete an original post with no replies. Someone should test.
There is no way to delete a post with replies but I can delete a post with no replies.
