Old_Field_Tech's avatar
Old_Field_Tech
12 years ago
T3 and T4 Timeouts from an ex-field technician
Starting in September of 2013, I noticed my connection becoming intermittent at best.  Voice conferencing and gaming would literally go from 23 ms to over 10k ms and then obviously I would disconnect from the server.  About a week after this first started happening, it started to randomly disconnect while I was simply browsing the internet.
I found the modem was cycling itself.  At the time I had an extremely old but trusty Motorola Surfboard SB5100.  Despite having this modem throughout the DOCSIS 3.0 updates, and despite it having worked fine through it all hither to the point in time, I figured it may be the modem (after a 12 year run, I wasn't complaining...)
I accessed the modem diagnostic page at 192.168.100.1 and saw that in the logs there were massive amounts of T3 timeouts.  Being an ex-field technician for Cox, I knew this could have gone one of two ways.  It was either the modem or it was something in the node (most likely an amplifier in the trunk line) that was to blame.
I called Cox for the heck of it just to see if they could see anything on their end, and as usual, no.  Everything on their end was fine, but again, having been a field tech for 5 years, I know that phone based customer service is very limited, they're not at the house, they don't have a meter and they're sure as heck not taking level readings.  Ok, fair enough.
I purchased a Motorola Surfboard SB6141 to replace the 5100 and finally upgrade to DOCSIS 3.0.  I called them, had the modem provisioned, went to the diagnostics page, was "wowed" by 8 downstream and 4 upstream channels, wondering why I had not upgraded the modem sooner, but alas, not 2 hours after provisioning, there was a T3 timeout.
Now I know it's not the modem, time to get on the phone and make things happen.  I called, they said they would send a tech out.  The tech (CONTRACTOR) came out and I explained the whole situation to him.  I showed him the modem diagnostics, I explained what I knew about everything, and he agreed with me.  He did NOT check levels, he did NOT check the tap at the pole (I have a 340 foot drop from the pole to the house, it's RG-11.  A new install was done less than a year ago, including the drop and inside lines, and I told him this, so he probably "assumed" things were good up there...).
He scheduled a 5C, which is the "internal" code name for "get a maintenance (plant) technician out to the pole to see what's up".  I got a call from my old lead technician about a week later.  He told me that the maintenance tech found water in the drop and cut it back to where the "stinger" (copper in the connector) wasn't black from water damage, and that another tech would be out in the next day or two in order to run a new drop.
Two days later ANOTHER CONTRACTOR comes to the house to run the new drop.  I  saw his spool of RG-11 and I knew he didn't have enough left to get from the pole to the house.  He removed the drop at the sub pole, and due to not wanting to bother him, I came back inside.  20 minutes later I went back out and he was gone.  He never replaced the drop.  He probably figured he didn't have enough cable to do it after removing the drop at the sub pole, rehung it, and left.  This pissed me off.
In the meantime I contacted my old lead and asked him what the deal was, explaining that not only were these T3's still happening, but they were getting worse, and they were leading into T4's.  He scheduled for the drop to be re-run AGAIN the next week and made sure it would be an in house guy arriving, NOT a contractor.
Sure enough, another lead technician and a field tech came to the house and ran a new drop.  They didn't have enough RG-11 so they ran half RG-11, then installed a ground block at the sub pole and ran RG-6 the rest of the way.  He said he would be back (this was a month ago and it still hasn't happened) to replace the RG-6 half of the drop with RG-11.  He gave me his cell number to contact directly if this kept going on.
It kept going on.  The T3's were getting worse.  I asked him on the phone to set up a 5C, he said he would but this was a week and a half after he replaced the drop and hadn't been out to finish the RG-11, so my faith in relying on him was null.  I therefore called customer service.  I explained that, despite having JUST bought a new modem, FIOS was a phone call away if this wasn't resolved.  Per usual, they went RIGHT back to square one and wanted to send out a tech.  I told them to stop reading the script from their screen and focus on their keyboard in order to LISTEN AND UNDERSTAND exactly what I had JUST explained to them.
For over a month I was implying that this was a plant issue, no one wanted to listen.  The phone techs didn't want to listen, the lead techs did not want to listen, the lead techs kept coming back with 50 other excuses as to what could be causing it.  I questioned them as to why they would do this when they knew I used to be a tech and I wasn't an idiot.
The final call was made to customer service.  Again, they said they had to send a tech out, despite two months of this **, in order to get a 5C scheduled.  Ok, last time I am playing this game.  The tech came out and I caught him on my way home from work.  He was an in house guy and I caught him as he was at the pole taking levels.
He told me that every port from the tap was bonkers, he replaced the tap and the levels were STILL bonkers, and that he did not understand how two lead techs and four field techs didn't realize this was a plant issue from day one.  I concurred.  He took down every piece of information I gave him about the new drop, the new modem, signal levels at the modem, etc, etc, and made a detailed log for the maintenance techs who came out.  He also told me that there are only SIX HOUSES ON MY NODE, LITERALLY.  This means that the trunk line feeding my house only feeds a total of 6 houses.  Do you know how easy that is for plant (maintenance) to troubleshoot?  There is one amplifier that is literally humping my tap, if here's an inch of trunk line from the amplifier into the tap then it's a lot.  I suspected that amplifier from the get go, but even if it wasn't, there would only be at most ONE MORE amplifier in that node, so yeah, one amp checked out good, guess which one's bad?  Real easy stuff here people, real easy.
So, the tech scheduled the 5C (the second one that had to happen in this whole fiasco), and the maintenance tech came out.  I don't know if it was the same or a different one, but this time around (after TWO MONTHS OF THIS **) the problem was resolved.  It has been two weeks and I have not seen a single T3 or T4 in my log.  I see where it lost connection due to the maintenance guy doing what he had to do and of course the service gets interrupted during this, but honestly, after the modem cycle, there is not ONE added entry to the log, nothing; whereas every other "visit" would result in a T3 less than 10 minutes later.
These T3 (and later T4's due to the issue getting progressively worse) were happening every ten to twenty minutes on some days, other days every hour or so.  I use VOIP for telephone.  Imagine not having 911 access for the whole day because your ISP can't get it's act together.  I held out having FIOS reinstalled (it was installed here when it first came out) because I honestly can't stand those hacks.  Having said that, had that last tech not been so thorough, had the second maintenance tech not done his job and resolved the issue, Verizon was seriously the next phone call.
I didn't go into a whole lot of detail about levels and diagnostics here because I did enough of that with customer service and all the techs that visited.  I wanted to make a point here to Cox.  Not all customers are complete idiots.  Not all customers have zero clue about how information travels from their house to the MTC.  Maybe instead of treating everyone equally as morons, you should start treating them all equally as intelligent folk.
Imagine how many folks out there were never field techs, imagine how many would have switched back to Verizon within the first week, let alone sticking it out for two months.  I was a field tech, I have working knowledge of the system, I was treated like a complete idiot, how do you think that makes me feel?  It actually makes me feel pretty damned good right about now knowing I was right the whole damned time about the issue being a plant related occurrence, but I can tell you right now when these people tell you over the phone and face to face that you're "wrong", and that they need to go through steps that, again as an ex-tech, you KNOW they don't need to go through, all the while the internet that we pay for monthly and (in some cases) our phone service (through another provider in my instance) has fallen to complete useless garbage, labeling it as "infuriating" somehow undermines the true nature of it.
I know that not every single problem faced is one of a plant issue, this is obvious.  Red flags should be raised, however, after every single other step has been taken and fails, instead of attempting to loop the same damned process all over again; that is simply ridiculous.  What is also ridiculous is the fact that contractors are being sent in place of in house technicians and basically this leads to repeat trouble calls.  This is something that is completely unacceptable, especially when one has to take time out of their day (or out of work) every time a call has to be rescheduled.  I know not every contractor is a bad contractor, but out of the entire bunch, I can name 3 that I would have work at my house, that's about it.  To make it relative to the in house technicians, I can list about 20 off the top of my head that I would let work at my house from start to finish with a cable job any day of the year.
I hope this type of issue, or at least the steps to the resolution of this type of problem does not happen again.  I will definitely be more prone to calling Verizon early on if an issue is not resolved in a suitable amount of time, not TWO MONTHS AFTER.
  • Health_Edge's avatar
    Health_Edge
    Valued Contributor III
    My god man, you wrote a BOOK!
    A good read though for anyone wanting to see what really goes on behind the scenes. Contractors...meh, they help keep a technicians job but they also help keep a technician's job miserable. They are the field equivalent of the technical support reps from India. Oddly enough there is a simular language barrier sometimes. '
    So basically you had a broken tap and Cox couldn't/wouldn't Fix it, so you switched ISP? Sounds logical and fair. Im surprised the story doesn't contain for empathy for Cox and the technicians though since you used to be one. Surely you know of all the red tape and stupid stuff they have to go through.
    So whats the moral of the story? Don't let contractors into the house? Have Cox double check your outside stuff if having T3 issues? Good post BTW.
  • DerrickW's avatar
    DerrickW
    Valued Contributor
    Hi Old Field Tech,
    I know this was an unpleasant experience for you given your background.  I will agree that the customer interaction should be more of a tailored experience, and we should adapt to the customer.  I am glad to see the issue was resolved, but there is definitely room for improvement.  Thank you for your feedback it is much appreciated, we do take it into consideration.
