What a scam - you have been charging me 70$ promootional rate and now just charged me 100$ for this ? With Spectrum I would have paid 25$ only for this speed. With T-Mobile home internet 30$
Did you want to troubleshoot? What modem and router do you have? Are you testing wired or wireless?
Get off WiFi and connect via Ethernet direct to modem. If you have a combo wifi/modem, you should be online, remember to disable the wifi on your device, if you have separate units, remember to power OFF the router, and then powercycle the modem. Test at several sights as they can provide differing results.
Gigablast is sold as a package which includes the Panaromic wifi modem/router. I have tested many times by powering off and leaving it powered off and then on. The bottom line is its a scam and they need to admit it as such. I want some of my money back cause I think this is not right to charge a hefty pricetag for something they cant possibly provide.
You really think Cox will "admit it's a scam"? Why are you posting here? What are you expecting?
You are NOT required to use the pano modem. If you want to use your own equipment, then go buy it and use it. Have you even tested your speed using ethernet? Testing over WiFi is inaccurate, no matter if you have thousands of dollars of equipment or rent the pano equipment. If all you want to to is b*tch, then goodbye. If you really want to address the issue, we can help. Your choice., Kvetch or address?
