nemerson74's avatar
nemerson74
2 years ago
Constant connection stuttering and drops (MODEM BROKE!?!)
I have a netgear CM1000v2 modem and a netgear r7000 AC1900 router. I live in an apartment so basically can only control up to the coax outlet.
For the past few days (after 2 yrs of working fine) I've had terrible stutter and connection loss. We had big storm with heavy rain and lightning in the area right before which may or may not be related to the issue.
I logged into the modem and saw a ton of critical and warning priority messages. The first ones before losing connection are "Dynamic Range Window violation" and " RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW " followed by a ton of timeouts (T2, 3 and 4 have been seen).
What I have done:
  • Replaced my coax cable with another RG6 to no avail (twice, one new)
  • Talked with Cox online and scheduled a technician visit (It's gonna be awhile). The guy online first said that my modem is broken but I was very dubious so just kept pressing.
  • Cried
I believe the voltages (upstream in particular) are too high. Is this true, and if so, what could the issue be? Should I replace my modem with a different model before the technician gets here just to test or is that most likely not the issue? Thanks in advance WiderMouthOpen.
Here are some signal and event log
Event Logs
+ A B C
1 2022-06-25, 22:29:32 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
2 2022-06-25, 22:29:28 Notice (6) Honoring MDD; IP provisioning mode = IPv4
3 2022-06-25, 22:29:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
4 2022-06-25, 22:29:07 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
5 2022-06-25, 22:29:06 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
6 2022-06-25, 22:28:59 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
7 2022-06-25, 22:28:58 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
8 2022-06-25, 22:28:57 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
9 2022-06-25, 22:28:56 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
10 2022-06-25, 22:28:52 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
11 2022-06-25, 22:28:48 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
12 2022-06-25, 22:28:47 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
13 2022-06-25, 22:28:40 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
14 2022-06-25, 22:28:36 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
15 2022-06-25, 22:28:36 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
16 2022-06-25, 22:28:28 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
17 2022-06-25, 22:28:27 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
18 2022-06-25, 22:28:24 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
19 2022-06-25, 22:28:17 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
20 2022-06-25, 22:28:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
21 2022-06-25, 22:28:07 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
22 2022-06-25, 22:27:57 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
23 2022-06-25, 22:27:56 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
24 2022-06-25, 22:27:56 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
25 2022-06-25, 22:26:06 Warning (5) Dynamic Range Window violation
26 2022-06-25, 22:26:06 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=44:a5:6e:b8:69:00;CMTS-MAC=6c:13:d5:75:ae:b6;CM-QOS=1.1;CM-VER=3.1;
Upstream Bonded Channels
+ A B C D E F
1 Channel Lock Status Modulation Channel ID Frequency Power
2 1 Locked ATDMA 1 17400000 Hz 56.8 dBmV
3 2 Locked ATDMA 2 23900000 Hz 56.8 dBmV
4 3 Locked ATDMA 3 30300000 Hz 56.5 dBmV
5 4 Locked ATDMA 4 36700000 Hz 56.3 dBmV
6 5 Locked ATDMA 6 12600000 Hz 54.3 dBmV
7 6 Not Locked Unknown 0 0 Hz 0.0 dBmV
8 7 Not Locked Unknown 0 0 Hz 0.0 dBmV
9 8 Not Locked Unknown 0 0 Hz 0.0 dBmV
Downstream Bonded Channels
A B C D E F G H I J
1 Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords
2 1 Locked QAM256 21 903000000 Hz -13.0 dBmV 40.2 dB 13690638 462 1628
3 2 Locked QAM256 1 783000000 Hz -11.7 dBmV 41.1 dB 392094046 37008 50358
4 3 Locked QAM256 2 789000000 Hz -11.9 dBmV 40.8 dB 509998892 4564 3693
5 4 Locked QAM256 3 795000000 Hz -12.5 dBmV 40.3 dB 510011420 0 0
6 5 Locked QAM256 4 801000000 Hz -11.9 dBmV 40.8 dB 509875222 0 0
7 6 Locked QAM256 5 807000000 Hz -11.3 dBmV 41.3 dB 509835406 0 0
8 7 Locked QAM256 6 813000000 Hz -11.9 dBmV 40.8 dB 509937204 1 0
9 8 Locked QAM256 7 819000000 Hz -13.1 dBmV 40.0 dB 509978335 1 0
10 9 Locked QAM256 8 825000000 Hz -12.5 dBmV 40.4 dB 510014692 1 0
11 10 Locked QAM256 9 831000000 Hz -12.1 dBmV 40.7 dB 510050792 0 0
12 11 Locked QAM256 10 837000000 Hz -11.6 dBmV 41.1 dB 344339069 35765 88971
13 12 Locked QAM256 11 843000000 Hz -12.1 dBmV 40.8 dB 344201525 79071 225388
14 13 Locked QAM256 12 849000000 Hz -12.0 dBmV 40.7 dB 510164981 0 0
15 14 Locked QAM256 13 855000000 Hz -11.7 dBmV 41.1 dB 510198946 0 0
16 15 Locked QAM256 14 861000000 Hz -12.0 dBmV 40.9 dB 510235230 0 0
17 16 Locked QAM256 15 867000000 Hz -12.0 dBmV 40.8 dB 510273344 0 0
18 17 Locked QAM256 16 873000000 Hz -12.7 dBmV 40.0 dB 510309032 0 0
19 18 Locked QAM256 17 879000000 Hz -12.3 dBmV 40.6 dB 510347747 0 0
20 19 Locked QAM256 18 885000000 Hz -12.0 dBmV 40.4 dB 510385940 0 0
21 20 Locked QAM256 19 891000000 Hz -11.5 dBmV 41.1 dB 510423977 0 0
22 21 Locked QAM256 20 897000000 Hz -12.8 dBmV 40.2 dB 510465578 0 0
23 22 Locked QAM256 22 909000000 Hz -12.8 dBmV 40.3 dB 6736364 2948 10132
24 23 Locked QAM256 23 915000000 Hz -12.4 dBmV 40.6 dB 8534041 6067 22051
25 24 Locked QAM256 24 921000000 Hz -12.8 dBmV 40.2 dB 13975852 6750 29750
26 25 Locked QAM256 25 927000000 Hz -13.5 dBmV 39.6 dB 254545213 45773 219884
27 26 Locked QAM256 26 933000000 Hz -13.1 dBmV 39.9 dB 510653059 0 0
28 27 Locked QAM256 27 939000000 Hz -12.6 dBmV 40.4 dB 510649727 0 0
29 28 Locked QAM256 28 945000000 Hz -12.4 dBmV 40.3 dB 510728018 0 0
30 29 Locked QAM256 29 951000000 Hz -13.3 dBmV 39.5 dB 510766443 0 0
31 30 Locked QAM256 30 957000000 Hz -13.7 dBmV 39.3 dB 510814669 0 0
32 31 Locked QAM256 31 963000000 Hz -13.7 dBmV 39.1 dB 510830691 0 0
33 32 Locked QAM256 32 969000000 Hz -13.8 dBmV 39.0 dB 510911916 0 0
