bbarnard's avatar
bbarnard
XR11 Remote help
Only two item this time...
1)  Is there a way to set up the box or the remote to start on "cable" rather than "channels"?
2)  When I move channels I want to go to start at a specific channel.  How can I do that?
Thanks Folks
  • Hi Bbarnard,
    Thank you for reaching out to us through Cox Forums! The link provided below will assist with your inquiry:
    www.cox.com/.../program-guide.html
    If this is not the information you were looking for, we will need some clarification with your inquiry.
    Maria L.
