The article I posted has different durations.
Yeah...I meant "no audio" but had sync on the brain.
I see but I didn't have to wait that long. I think it has something to do with the audio buffer. When I first hooked up my BR player it wouldn't give audio but if I changed the audio input settings on the TV it would give audio for a second then go away. Wouldn't matter what setting I selected, it would only give audio for a second.
I wish Cox separated posts from comments on your profile so you could easily find your posts.
Why not wait that long? Article calls it a "soft reset." Perhaps a "hard" (factory) reset has a different process.
Because waiting less time worked? Not sure how to answer that. I wasn't following a procedure. I was just winging it and about 10 seconds works for me. YMMV
Yes, but you're only rebooting. Try resetting. I'm not suggesting this will work...but it's something different.
Maybe if I have the problem again but haven't observed it since the factory reset. I will talk to the other TV watchers and give them that advice.
Oh, I misread your post. I thought it still reoccurs with apps after factory resetting to troubleshoot your BR player. Glad it's fixed.
- 4 years ago
- 11 months ago
- 6 years ago
- 2 years ago
- 8 years ago
