AWG70508's avatar
AWG70508
2 years ago
TV sound not synced
My Samsung Smart TV voice sound is not synced with mouth movement? Off about a second but recently noticeable.
  • WiderMouthOpen's avatar
    WiderMouthOpen
    Esteemed Contributor III
    So I can look over the manual, what model TV do you have? Also, how do you have the cable box connected to the TV? Any audio system or sound bar?
    I also have a Samsung TV and the audio stops sometimes and I have to power cycle the TV to get it to work. Have you tried that?
      WiderMouthOpen
      You can find the model number by going into Settings > Support > About this TV > Model code. I have the UN43NU6900.
      The audio just stops?  Is the audio from your TV speakers?  I know you've ensured all firmware is up-to-date.  Where does your TV gets its programming?
    The speed of your audio signal may actually be correct or normal, but your video signal may be out-of-sync.
    Disable any video-processing on your TV (and/or receiver), such as motion enhancement, video enhancement, video noise reduction, etc
    If your audio and video get back in sync, you can re-enable enhancements one-by-one to find the culprit.
  • DRVEGAS's avatar
    DRVEGAS
    Valued Contributor
    My Samsung has the same issue but I'm using Dish Network not Cox 🤔
    Lots of kudos in here...but we ain't fix nothing.
