I had similar issues that drove Cox and me mad for several months. After about 10 service calls and twice as many calls with support, the next guy I spoke to, who really knew what to look for, found a bad channel in large panel that fed my neighborhood. To my knowledge mine was the only home having issues. They fixed that issue and never had any of the frustrating symptoms of a weak digital signal again. Note that all measured levels my cable boxes were within acceptable limits, but that big panel was still serving up horrible internet speeds and enough picture freezes to lower the world’s ambient temps.
thanks. I suspect Cox cable issue on this street. My cox cable tap is box above ground with only one other house attached.
- Becky2 years agoModeratorHi Ron, that sounds like an incredibly frustrating issue and it must certainly impact your enjoyment when watching Cox TV content. You've done some great troubleshooting on your own! It may be time to have a tech come out and ensure there isn't an intermittent signal issue to your home. So that my team can further assist you, please email us at cox.help@cox.com. -Becky, Cox Support Forums Moderator
- Ron20012 years agoNew Contributor
Becky, going to check all wiring inside house first and then if still have problem would appreciate Tech checking out at street: levels, etc.. I will let you know.
- DavidA22 years agoFormer Moderator@Ron2001
Thank you and please do. We want your service to work how it is supposed to.
David
- 24 days agokcostel8621
- 12 months agojebediah
- 11 years agoPwar
