Hi Bruce, I have an LG B7 65” OLED tv and the only way it will connect to Ethernet is to restart panoramic modem/router, reset tv, start set-up select Ethernet wired connection, plug cat7 in and it connects. As soon as I turn the tv off and turn it back on there is no wired network connection and it will not recognize the Ethernet cable going into the port. My son has a 4K Lg webos tv and the Ethernet connection works flawlessly. I realize my main tv is more sophisticated, but is there something with my modem/router settings that can be changed to make it work?
I’ve even tried a usb 3.0 to Ethernet adapter but when I plug that connection it it says it’s an unrecognizable device and I can’t even access it.
I have an Ethernet wire going directly into my Apple TV on this same television and it recognizes the Ethernet connection at all times.
i have been trying everything and there are no software updates.
thank you for your help!
no software updates
Oops...I didn't catch that nugget at first. What software version do you have?
- 5 months ago
- 9 months ago
