Allan
5 years agoModerator
@Bkmoore4113, Are the tuning adapters flashing or are they solid? Also, are you getting any error messages on the screen? -Allan, Cox Support Forums Moderator.
bkmoore4113
5 years agoNew Contributor
Allan - the TiVo that was the initial source of the problem has a flashing yellow light. Neither technician even tried to resolve that issue. The TiVo that was initially working and now has absolutely no channel access has and still does have a solid yellow light on the tuning adapter.
Depending on the channel, I am getting either a v52 or a V53 error.
- JonathanJ5 years agoFormer Moderator@Bkmoore4113
Those error codes mean there's a signal issue. Check the coaxial cable connection on the back of the device and make sure all cables are secure.
Cox Moderator- bkmoore41135 years agoNew Contributor
Exactly. Technician claims that signal is “perfect.” On previously perfectly working TiVo his tinkering essentially has bricked the box. On the other TiVo that was the source of the initial issue, the technicians work didn’t change anything.
