Dear Allen,
Thanks for all your help. You have been very kind and patient with all my questions. I feel like I became my mother. I used to be the one that understood things and would help HER program the VCR. Now I have BECOME the one that needs help all the time with the newer electronics.
The VCR is Emerson, brand new, just out of the box, but I think old by mfg. date. It was given to me last week by a friend that had it and never used it. Still in original packaging. Very basic. Just a 4 headed VCR, nothing else. No DVD or anything. The instructions that came with it consist of two pages so not very informative. It does have directions for setting the clock and programming VCR to record at specific times.
After following the instructions for setting the clock, I pressed "display" on the VCR remote and the time appeared on the TV screen. After about 15 minutes, the displayed time remained the same as the time set, and had not advanced.
I turned both the TV and the VCR OFF, leaving the mini-box powered up as it remains at all times. Hours later, I turned on the TV, just the TV, I left the VCR off, and the time displays automatically for about a minute or less. It had the correct time but it is coming from the television, not from the VCR.
Is the TV clock interfering with the VCR clock? Does the signal from the cable company through the mini-box contain any time information?
I am guessing I can do two things to test the situation. I can replace the VCR with an older one that I have and see if IT works and the other option may be to remove the mini-box and see if the current VCR clock works if the mini-box is not in the lineup.
Based on prior usage (before the days of digital and mini-boxes), even if the TV had a clock, you set the time in the VCR if you wanted to record at a specific time and date. The TV clock need not even be present. In fact, some older TV's did not have clocks. The clock on TV's appear to me to be needed for sleep timer purposes or alarm purposes. It did not seem to matter if the TV had a clock or not, nor if it had a different time from the one set on the VCR. The VCR only paid attention to the VCR clock, not the TV.
Am I on the right track? I know this is a little OFF TOPIC from where it began, but it is still in line with using a VCR WITH a mini-box. I never had problems using a VCR until the mini-box became a necessity to get a signal.
I do realize that if I remove the mini-box from the lineup to check the function of the VCR clock, I will NOT get a signal. I also realize that I am now talking about an issue with a VCR clock, and not the original topic. I guess my biggest problem is not understanding exactly what the mini-box is doing beyond modulating between analog and digital. I like "simple" and use the KISS principle. For me, the more "add-on's", the more complicated and the more I don't understand. I am old enough to remember using a black and white TV with rabbit ears, that you walked to the TV console to change the channel to one of the 3 broadcasting stations. No such thing as a remote control. No cable, satellite, or the like. Thanks again for your patience.
Thanks again for all your prior help.
