DRVEGAS's avatar
DRVEGAS
Valued Contributor
2 years ago
Question
How do I delete an older post here?  All I can see is the option to edit an older post🤔
    • DRVEGAS's avatar
      DRVEGAS
      Valued Contributor
      Only because it's no longer needed but I guess your right that we can't delete them.
      • WiderMouthOpen's avatar
        WiderMouthOpen
        Esteemed Contributor
        It's a good idea to keep questions because someone else may search google and come across them. It helps answer questions before they are even asked. They are locked after 1 month of inactivity though.
    As long as nobody replies directly to your previous post, you can delete it.  If someone does reply, it's locked in; however, you can edit the replied-to post.
      Oops...you may be referring to an original post within the Forum.  No, can't delete it.  However, I've never tried to delete an original post with no replies.  Someone should test.
      • DRVEGAS's avatar
        DRVEGAS
        Valued Contributor
        There is no way to delete a post with replies but I can delete a post with no replies.
