Moms disabled and needs more time to get to the phone. Cox tech support says I’m stuck.
I didn't see the option in the Cox setup article but found a couple aged posts:
forums.cox.com/.../set-amount-of-rings
forums.cox.com/.../amount-of-rings
Yes, you can login to voicetools.cox.com and adjust the number of rings.
From the Voice Tools webpage:
These steps only need to be performed once to set the number of rings before incoming calls are forwarded to voicemail. The number of rings selected can be changed by repeating this process.
Seems *78...if its still works...would be vastly quicker for Mom than logging in and clicking 15 things.
Picking up your phone and pressing *78 would have been vastly quicker than typing what you did.
*78 doesn't work. BEEP BEEP BEEP BEEP
