webmail print out size too small
When ever I print a Webmail email it always comes out too small on mine or anyone else's computer.
HOW/WHERE DO YOU CHANGE THE PRINT OUT FONT SIZE IN WEBMAIL?
Thank you,
I've seen something similar before with gmail. You should do this just to eliminate it as a possibility.
With an email message open, on your menu bar click File>Page Setup. Look for a box labeled Enable Shrink to Fit or Shrink to Page Width or something along those lines. Make sure the box is unchecked.
Now this only applies if you're using File>Print on the menu bar to initiate printing and trying to print the whole page.
If you're using the Print button above the webmail message, when the "to be printed" window appears, be sure to click the printer icon in the window, not File>Print. You could, but again you would want to uncheck the "shrink" box in Setup in the second window.
That was as clear as mud. Short version: Only print from within the webmail window, not from the menu bar.
