dougbrown1952's avatar
dougbrown1952
8 years ago
Why does Animal Kingdom TNT have a running commentary?
For the last weeks, Animal Kingdom on TNT has had a running commentary for the whole program.?
  • That sounds like you may have video description turned on by accident (if you are using contour 2). This can be turned on/off by clicking the down arrow once and a small menu will come up at the bottom of the screen. Scroll over to the far left and once video description is highlighted you can click OK to turn it on/off. It will show the current status of either on or off once it is highlighted.
    Edit: Also tested the episode under on demand and I was not hearing any of the additional audio on last week's episode.
    Brian
