Kaye1's avatar
Kaye1
11 months ago
TV sound not matching picture
My tv sound and picture are not matching up? I’ve tried resetting cable box, turning off tv, unplugging everything and nothing works? Any suggestions or magic handshakes?
  • CurtB's avatar
    CurtB
    Honored Contributor
    If it only occurs on one channel, it's probably an issue with the source network. (It seems to happen most often with CW).  If it's on all channels, you probably have a signal issue, but you should check your TV audio settings and experiment with available options before scheduling a tech.
  • jmc2020's avatar
    jmc2020
    I have this same issue, especially with Peacock.  It helps to restart the program, or if that doesn't work, to turn off the tv and restart the Panasonic Wifi.
