AWDP
2 years agoNew Contributor
Volume Issues
I am having an issue with the volume going out on channels.
It has happened on Bravo and the USA Network.
Please help.
Bravo and USA are under the same division, NBCUniversal Cable, so it may be an issue with your local affiliate distributing both signals?
I'd ensure Contour is configured to only process audio as stereo.
Contour button > Setting (gear icon) > Device Settings > Audio > HDMI Audio Output > select Stereo (PCM)
If you've connected an optical cable to Contour for audio, do the same for the Digital Audio Output (optical/SPDIF) setting. If not, ignore.
