Hiphubby123's avatar
Hiphubby123
4 months ago
Cox Remote Battery Life
I replaced the batteries in my Cox Cable remote but the onscreen battery life indicator still shows a low percentage of 31%.  Isn’t the percentage supposed to update to show 100% after you put new ba...
  • Hiphubby123's avatar
    4 months ago
    I did check the batteries and they were good.  However, I decided to change them again and the next set of batteries worked.  The onscreen battery strength indicator now shows 100%.  Odd, but the batteries that did not seem to work were Energizer and the ones that did work are Duracell.  Maybe the remote prefers Duracell.  No, I doubt that has anything to do with it but it was strange.  Problem solved.
