WildOne46
7 years agoNew Contributor
Power saver
How do you adjust the time b4 sleep mode applied I understand it is about 4 hrs by default. I cannot find the adjustment in settings only turning it on or off
PS I have a contour 2 (pace) box
UPDATE
Found method to set time on power saver function The default is 4 hrs. If you allow the power saver to activate, usually no activity overnight the light on the box will turn off ,& go into sleep mode. When you power up the TV using contour remote next morning this awakens the box & light will turn on. In the upper right hand corner of TV a msg will appear indicating amount of time box in sleep mode Press info on remote & get menu to change time interval; 1,2,4,6 or 8 hours or off
UPDATE 2:
Appears on 12/5/18 this option was removed with firmware (?) update...no longer available
