CRT's avatar
CRT
8 years ago
No sound
I have no sound on the Bravo channel.  The sound works on all other channels and SAP is off.
  • MarkM1's avatar
    MarkM1
    CRT,
    Are you having the problem with your sound on both the HD channel as well as the SD channel? We would like you to try a reset of the equipment as well to see if that corrects the problem. Please disconnect the cable box from power for 1 minute & then plug it back in. Let us know if this works for you.
    Mark M.
