Can you disable the wireless card via the settings on your LG? The wired port probably has connectivity to your router but if the wireless also has connectivity, the LG defaults to wireless. I'm not sure but perhaps there's a priority with 2 active ports or 1 active port may be disabling the other.
- rcaron6 years agoNew Contributor II
No. Unfortunately, there isn’t a way to do that. Thank you
