twintriode's avatar
twintriode
2 years ago
How to use XR11-RF remote to control volume on the HDMI cable coming out of a Contour mini-box?
My main Contour box is in the Living Room. I have a Contour mini-box in my kitchen.
Connected to the Contour mini-box is a Samsung T37F LED Monitor which has no audio.
I have a HDMI to audio adapter connected to Logitech speakers.
I'd like to be able to control the volume using the volume button on the XR11-RF remote.
Channel works fine. It gives a green light and changes the channel.
Volume does not work. It gives a red light and does nothing.
I checked some Forum answers.
All the forum answers are outdated.
7-9 years old.
Please provide updated instructions on how to program the remote to control the volume on the HDMI cable coming out of the Contour mini-box.
    • twintriode's avatar
      twintriode
      No help. The steps don't track with the XR11-RF controller.
      • WiderMouthOpen's avatar
        WiderMouthOpen
        Esteemed Contributor II
    The red light on the XR11 means its sending an IR command.  Does the Logitech have an IR receiver or come with a remote?
