MichaelJ
5 years agoModerator
Hi Drewster2448, please check all your connections to make sure they are at least finger tight, and if they are loose tighten them. Check for splitters too. Have you noticed any issues with the volume on any other channels? Does the issue happen on more than one TV?
Thank you,
Mike J.
Thank you,
Mike J.
