At the screen bottom right there is a Language Setting icon that has 3 buttons that can be slid on/off. the 2nd is Secondary Audio (SAP).
You can also toggle SAP by pressing "S" on the keyboard.
? - Display keyboard controls
C - Toggle closed captions
M - Mute audio
S - Toggle SAP
V - Toggle video description
Here is a Cox ticket from July 16...CUI000008292144. I tried looking for an on-site ticket tracker but no luck on finding anything. When I chatted with support team, got a "being looked at"
At least the SAP and Video provided some relief toward the problem for TV and cell. CurtB shortcuts (type ? or look at gear) gives some helpful hints. Some station fixes is better than nothing.
- CurtB6 years agoHonored Contributor
You can email cox.help@cox.com and ask for a status update for your ticket. But if their pattern holds, you'll probably just get a polite response from them too, that your ticket is being investigated.
- letti0016 years agoNew Contributor III
I have mentioned this before but will mention it again. The channels have sound when I use TV Go, as if I were not home. If pressed to watch a channel with no sound, I can switch over to TV Go.
One of you might want to consider reviewing this thread to consolidate everything you've learned into a single, consise email to cox.help@cox.com with the ticket number in the subject. Be sure to include the market you're in. Cox has that information, but I wouldn't leave anything to chance. I also wouldn't assume anyone from Cox reads everything here and passes it along to someone who can actually fix it. Something you've discovered might trigger a "Eureka" moment for one of Cox's video engineers. It's a long shot, but all it will cost you is a little of your time.
- Becky6 years agoModeratorHi Everyone, our video team is investigating the issue causing no audio on some channels on watchtv.cox.com and the Contour App. We appreciate all your troubleshooting details and have forwarded this info to the video team. We’ll update you as soon as we can. -Becky, Cox Support Forums Moderator
- 6 years ago
- 2 years ago
- 11 years ago
