I tried restarting Firefox, and finally restarted my computer....no luck, cannot re-logon to watchtv. ID/pass, who knows...must be on COX side...at least my TV works. Frustrating for you Apps/online guys with no sound or connections
KevinM2....I'm using Firefox, and do have problems with the login. Cleared the cache, history here. It sometimes works and other times fails. I've used Chrome and Edge. I'm able to login/off and re-login to these, so far. With FF, I can't seem to pinpoint the problem...after enter of id/pass, the screen re-displays and I need to re-enter id/pass then I get a message. I've been trying to play with different login paths to the watchTV for Cox... I see an Adobe Flash msg on the Chrome/Edge, but I believe that is after my ID verify. With FF, I get the Whitelabel error from above. I've also looked to see if there are any bloc of the idm.east.cox.net
Now about the original poster's, not getting sound on the TNT 18/1018 channel. I get NO sound using all 3 browsers....there may be others, but TNT is a no sound for me.
