Billy_Bob's avatar
Billy_Bob
3 years ago
Contour box need to be plugged in?
My master TV finally died after 18 years of service. In preparation for the replacement TV, I unplugged my Cox Cable Contour device. The next day my other TVs died also. Is there a connection between the device disconnection and the loss of cable TV elsewhere in the house?
  • If the other TVs aren't damaged but have no signal, they probably use client boxes that require the host Contour box you unplugged to be plugged in and connected.  Power off all boxes.  Reboot the host first.  When that finishes, power on the client boxes, one at a time.
  • CurtB's avatar
    CurtB
    Honored Contributor
    • WiderMouthOpen's avatar
      WiderMouthOpen
      Esteemed Contributor II
      Could you inform me which boxes use this technique? I thought only Whole Home DVRs used MoCA for DVR service to the client box. I didn't know it actually used the host box to stream TV.
    WiderMouthOpen
    When you say the TV died, can you explain? Does it power on? Does it show the menu/settings? If two TV's broke in the house at the same time I would guess you had a surge somewhere that damaged both. Any recent storm or power outage?
    ::edit:: Removed incorrect information.
