Ron2001
3 years agoNew Contributor
I had similar issues that drove Cox and me mad for several months. After about 10 service calls and twice as many calls with support, the next guy I spoke to, who really knew what to look for, found a bad channel in large panel that fed my neighborhood. To my knowledge mine was the only home having issues. They fixed that issue and never had any of the frustrating symptoms of a weak digital signal again. Note that all measured levels my cable boxes were within acceptable limits, but that big panel was still serving up horrible internet speeds and enough picture freezes to lower the world’s ambient temps.
thanks. I suspect Cox cable issue on this street. My cox cable tap is box above ground with only one other house attached.
No change.
lightening strike several months ago which did get into my receiver and TV
What do you mean...lightening fried your receiver and TV? If each is on the same electrical outlet, maybe. If it traveled through your cable system, your cable-box and modem(s) should have also taken a hit. How's the grounding cable look at the NID bolted onto the side of your house?
You're correct about radio frequencies carrying data and some frequencies could be vulnerable to interference from other sources also broadcasting on the same frequency. However, this would be on specific frequencies or specific TV channels. Have you noticed if all channels drop or only a couple?
Care to ask the other House if they're experiencing the same symptoms?
Have replaced only signal splitter with amplified version.
Try a regular coaxial splitter. Too much of a signal can be just as bad as too little. Signals must be within a range.
Had a service call by an experienced technician. Verified cox tap at street, various coax runs. Replaced several connectors and "barrels" and short cables and found a high noise level on one run of coax that is run under a floor. Confirmed that TV would drop out without any "loss of HDMI to a receiver first and then receiver sending HDMI to TV. Bottom line is seems to be fixed. Do have one run of coax with a problem but not Cox problem. If I get problem again with TV will have to determine new way to run Coax to location feeding set top box. Very satisfied with Cox service on the call. He checked every thing and did all he could. Cleaned up little problems here and there but little problems can add up in a whole system. Nosie inside house on coax is the real problem and my problem to fix or not..
Does this make sense? Is the tech suggesting a faulty TV?
What is causing the noise? What else is down here under the floor? If streaming was fine, it has to be something broadcasting on the same frequencies as cable-TV channels. What have you changed in the past few months? Is there an HVAC system down there? Does it have a wireless feature? Did you nail something into the floor?
If this had just started, you changed something. If you had a series of short cable segments joined with connectors and splitters, these needed to be replaced but you had these before the problem, right?
