techwolf777's avatar
techwolf777
4 years ago
Upload speed issue
With the plan I have, I should be getting 10Mbps upload. For the past month, I have been checking daily and I get anywhere from .6 to 1.5 Mbps. What can I do to get this upload speed more consistent with the plan I have purchased?
I have tried a few guides on network config settings.
The PC I test from is cat 8 wired directly to the COX supplied modem/router.
I test from many different sites including the COX speed test site.
I have tested from several different devices on my network and they are all reporting the same range.
I have swapped out network cables as a “just in case” measure.
At this point, I am out of ideas. Does anyone have any other thoughts?
  • techwolf777's avatar
    techwolf777
    Hey Wider. Yeah, they look like that. My interface scrolls to the right so this is gona be messy.
