iBloodhunterTV
3 years agoNew Contributor II
i have there highest plan and just the past day or so. my upload speed drops to .3 mbps on just about any speed test site i try. same thing seems to happen every year..
Darkatt
3 years agoHonored Contributor
Are you testing using ethernet or WiFi? What modem/router are you using? Are you really on the 2 Gbps plan which is the highest plan?
