Bray918
3 years agoNew Contributor III
Also, during peak hours it's 27 to 29 SNR. anything under 35 SNR i have issues.
- Darkatt3 years agoHonored Contributor
SNR of 31 or less is noisy. Do you have a cable amplifier hooked up inside the home? If so, I would try removing it, because they add noise. Also, if you have multiple cable connections in the home, verify that all of them are snug, and nothing is loose. If you have connections that aren't being used, I would get them disconnected from the feed. The fewer splitters, the better the signal levels, and less of a chance of getting ingress or noise in the lines.
