could this break in hop cause loss in connection when it comes to VOIP? my speeds are fine they are like 600mbps and my uploads are 30mbps. im just having issues when talking on the phone through VOIP
It's not a break. The edge routers know the destination for your ping, are forwarding the ping into the Internet but just aren't responding to you. An administrator probably configured the router to not reply to every ping. It's like Chris wrote: an administrator de-prioritized ping messages (ICMP).
Have you tried to reboot or reset your telephone modem? Are you using a VPN? If so, have you used your phone without the VPN?
- ebisha5 years agoNew Contributor
im using a headset directly connected to my PC. I don't know if its VPN. i am using my pc to connect to my jobs remote server to log in to one of their computers remotely. I don't know if that answers your question.
