Does your router assign IP addresses to your smarts? You may have to view your router logs or some type of network view.
Yes it does assign ip to each smarts
So the devices are on your home network but your app(s) can't access the devices to determine their statues?
- Jags6 years agoNew Contributor II
Exactly
So your devices are actually connecting but its your app not being able to connect.
How does the app work? For example, if I need to reset my modem, I have to get on the Internet, log into the Cox domain and click a button in my account to reset a modem setting 3 feet from my computer.
Do your apps monitor/administrate from the cloud?
Does your app have to be on the same network as the smarts?
When you connected your smarts to your neighbor's network (with his permission), were your apps also on his network?
